Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-12-2010, 06:11 PM
jsnowbordr47 jsnowbordr47 is offline
location of door lock relay 95 Suburban
Had a post a while back about bad door lock actuators. I tried new actuators and tried cleaning contacts, etc. No dice, only the drivers door has full operation. Other doors will lock but will not unlock unless I continue to press the button several times. Unless anyone has any ideas, I'm thinking it's the door lock relay.
I can hear it click underneath my dashboard, but I can't visually locate it. Does anyone know what to look for? And is it fairly easy to replace? I've heard that it has a live wire and that I need to disconnect the batter when replacing it. Is that true?
Other than the relay, what else could cause this situation?
Thanks for ideas.
Old 08-13-2010, 08:40 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: location of door lock relay 95 Suburban
Relay is on the right of brake pedal bracket.
But relay powers all doors at the same time.
What size sub 2 0r 4W and what engine?
You may have a wiring problem or weak switch.
Check switch and wiring to actuators.
MT
Old 11-28-2010, 07:03 PM
Well, we finally got it fixed. It was the door lock relay. I guess it was broken enough that it wasn't sending out enough juice for the unlock to the doors other than the drivers.
We didn't even get a new relay we just swapped it out for one from our 94 Suburban which is still in the process of being rebuilt. Now it all works. We even swapped out a door actuator from the 94 to the 95 and finally for the first time since 1998 the rear barn doors lock and unlock.
When I asked the parts guy at my local GM dealer he wasn't sure what it could be because he said these era Suburbans/GM trucks hardly ever have door lock problems beyond the actuators. (I told him we tried a new one and it still didn't work) He guessed a wiring problem.lol
Old 11-29-2010, 05:20 AM
MT-2500's Avatar
AF - Advisor
Thanks for posting back how it went and the fix.
Good luck
MT
