Heater/blower runs with key off
I have two problems and they may be related I don't know.
Last night the battery went belly up in my wifes 2000 Grand Prix GT. After replacing the battery today I found the remote start/lock/unlock won't work with the key fob. It was working fine up until then. Second problem, I noticed today the heater/AC blower stays on even after the key is turned off and removed. The only way to get it stopped is to turn it off with the heater/AC blower knob. This isn't normal is it? This could be what ran the battery down last night but it was an old battery too. Any ideas if these two problems are related and/or a remedy for them? Thanks! |
Re: Heater/blower runs with key off
Have you tried reprogramming the key fob? There is a write up on how to reprogram each transmitter on the Tips and maintenance subforum, you should give it a try.
About the blower, maybe you have a bad switch have you tried to turn the key switch without the key to see if it moves and the blower turns off?
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
does your car have the automatic climate control, or just manual a/c controls?
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Hey guys,
Thanks for your replys. It turns out the battery going dead caused both my problems to occur. Problem was solved and got things working again like they should by unhooking the neg. battery cable a few times until there was no spark at the cable when it was hooked up again. I guess this cleared up all the garbage the computer had got by the battery going dead. So now the remote works again and the blower/ac goes off like it should when you shut the car off. I don't know what the deal is with batterys these days. You get absolutely NO warning they are about to die. They just go belly up suddenly and thats IT! Use to the starter would begin turning slower and slower and you had an idea the battery needed replaced but now you can get stranded anywhere with no warning at all. Kind of frustrating. |
