Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 08-11-2010, 11:29 PM
SHEPARD327 SHEPARD327 is offline
99 saturn sl goes wide open
Hey, Im new here so go ez please. My 99 sl when started would idle at about 2000 rpm , no codes. replaced the maf sensor on the intake, no change. replaced Iac and now it idles at 4000 rpm, any one had something simular?
Old 08-13-2010, 02:19 AM
mike5670 mike5670 is offline
Re: 99 saturn sl goes wide open
I had this problem with my 96 saturn change intake gasket it quit it was sucking air in the corner near the power steering pump
Old 08-14-2010, 01:37 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
I'm assuming you meant to say "MAP" (Manifold Absolute Pressure) sensor as the S-Series never had a MAF (Mass Air Flow) sensor. Check your vacuum hoses and make sure the clamps on your air intake are tight. Your throttlebody may need to be cleaned too. Just spray some throttlebody cleaner (do NOT use carb cleaner) around the throttle plate and make sure it closes all the way. It very well could be a bad intake gasket as they do fail quite often on the SOHC engines. Spray some throttlebody cleaner around the base of the intake and if the idle changes your intake manifold gasket is bad.
If your engine coolant temp sensor has the plastic tip you should replace it with a newer, brass tipped sensor too. It is a cheap part that causes all kind of weird things to happen when it fails. It is located on the driver's side of the cylinder head.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
