Old 08-11-2010, 02:57 PM
Redline69 Redline69 is offline
2000 Windstar- Engine/accessory squeak
Hi everyone.
New member here.
As mentioned,I have a 2000 Windstar, 3.8L V-6. It recently developed a squeak that 1st I thought was the fixed accesory idler..Nope. Then I was 99% sure it was the waterpump..I did my research here,and with some blood,sweat and tears..managed to get that replaced. Went with a re-man water pump. Now after all that,the dang squeak is still there!
What could it be? I checked the tension idler..seems OK,as are the AC compressor,and the PS pump. Seems like it's coming from behind the waterpump? That possible?
Now before I get the rest of the cowl back in,I'm hoping for some ideas.
Appreciate any feedback
Frank.
Old 08-11-2010, 04:37 PM
12Ounce 12Ounce is offline
Re: 2000 Windstar- Engine/accessory squeak
Very Possible ... and probable!
Search for "synchronizer" and/or "cam position sensor".
(Did you ask before? I don't recall.) Oops! I see its your first post.
Old 08-11-2010, 04:50 PM
BTW ... Welcome to the forum!
Old 08-11-2010, 07:01 PM
Appreciate the welcome.
So that part,the synconizer,sits there by that small metal water pump line,atop..I guess you'd call it the water pump body?. I recall disconnecting the line from it when I did the waterpump job.
So just remove the cap,and run a bit of oil down there. Maybe some grease with a needle?
I mean,it's already an occasional chirpy squeak..might it need replacement?
If I was to replace it,does the new one have to go in a certain way?
TIA~
Old 08-11-2010, 07:58 PM
OK,
Found this thread regarding replacement.
http://http://www.automotiveforums.c...t=synchronizer
Unfortunately,I have no experience with any kind of timing related issues. I think I'll just try and get a couple drops of oil down there for now,and maybe grab a new to keep around for the future..just in case.
Old 08-11-2010, 08:28 PM
Good plan. If you use clean motor oil ... and let it sit overnight ... enough oil may slide down the assembly to stop the squeak. Good luck!
Old 08-11-2010, 09:01 PM
wiswind wiswind is offline
I recommend the following to determine if it is something driven by the serpentine belt.....or something else......like the syncronizer......
This is a TEMPORARY test......only run the motor for just long enough to quickly check to see if the noise is still there........
Remove the serpentine belt, start motor......noise still there?.....then it is not on the belt......
Noise gone?.....most likely something driven by the belt.......you still have the tensioner pulley.......A/C compressor and water pump (last resort).
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 08-11-2010, 09:42 PM
I now know I should have tried that trick BEFORE already changing the fixed idler,and water pump...lol.
Still a good idea,to make sure it's NOT something else on the accessory drive.
Old 08-12-2010, 02:33 PM
mark_gober mark_gober is offline
I haven't replaced a timing belt on my windstar, but almost every timing belt I've EVER replaced has a tensioner pulley. My Kia had almost this exact problem and it turned out to be the timing belt tensioner. When you replaced the water pump, did you get a new timing belt or tensioner? The location would be in very close proximity to your waterpump and would be behind it.
Mark
Old 08-12-2010, 03:36 PM
phil-l phil-l is offline
Mark -
Not on a Windstar 3.8 - which uses a timing chain...
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 08-15-2010, 07:36 PM
customtileus customtileus is offline
Hi new here I have a 2000 ford windstar 3.8. there is a pin that has come off on the side of the motor that moves a lever on the eng. does any one know what this is? near the alternator.
Thanks Rusty
Old 08-15-2010, 08:35 PM
crrobbins crrobbins is offline
customtileus,
can you post a picture of lever?
Old 08-15-2010, 11:51 PM
Waxhaw Waxhaw is offline
customtileus,
Welcome to the Windstar forum, great place.
Look at these threads:
http://www.automotiveforums.com/vbul...d.php?t=764861
http://www.automotiveforums.com/vbul....php?t=1038194
Also it's usually good to start a new thread when having a new topic - since this has not to do with a Engine/accessory squeak
Cheers
Waxhaw
'85 VW Jetta diesel 150k '95 Taurus 3.8 137k
2001 Windstar 3.8 126k
Old 08-16-2010, 04:11 PM
Originally Posted by phil-l View Post
Mark -
I'm an idiot...I'll bow out into the corner now. I own both a '95 and '00 Windstar that I've done TONS of maintenance and I've never actually determined that it had a belt or a chain. Sorry.
Mark
Old 08-16-2010, 04:26 PM
Mark,
Someone who has done tons of maintenance on a '95 and '00 Windstar is no idiot.
Take your bow but stay on stage, we need you here!
Cheers,
Waxhaw
