Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-11-2010, 01:30 PM
lookforthesignals lookforthesignals is offline
99 V6 Mustang ticking when accelerating
hello. thanks for reading / helping. i have a '99 Mustang LS V6. it has been ticking when accelerating. it sounds like its coming from the front of the engine area, but i cant tell on what side. when driving at a consistent speed, no matter how fast, it does not tick. only when i take off from a stop, or when i have to accelerate to pass people on the freeway.
im planning on a trip to vegas from california. about 275 miles each way. is there anything i can do for a quick fix- or do you think its too far of a drive (i dont want to blow my engine).
any advice would be great. thanks again for the help!
Old 08-11-2010, 02:37 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 99 V6 Mustang ticking when accelerating
Could be timing chain tensioners if it's coming from the front engine cover.
Does it sound like a a bunch of marbles being shaken in the engine? That would indicate engine knock which can be damaging.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 08-11-2010, 02:46 PM
it sounds more like higher pitched tick. almost like you can hear the pistons moving up and down. i can only tell that i am hearing it from under the hood. i thought it was an oil issue, and i changed the oil and the oil filter and air filter, but it didnt help much.
the noise speeds up when i get my rmps up, but when i hold at 2 there isnt any ticking noise.
Tags
accelerating , maintenance , mustang , ticking
