Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 08-11-2010, 12:07 PM
bkw bkw is offline
1974 b200 brake problem
having a problem with my 1974 dodge b200 brakes. when i have my foot on the break pedal while sitting at a light or stopped the pedal will slowly go down. the brakes work fine when stopping otherwise.
any thoughts?
Old 08-11-2010, 08:23 PM
alloro alloro is offline
Re: 1974 b200 brake problem
Either you have a leaking wheel cylinder or the internal seal for the master cylinder is worn out. If it's a wheel cylinder you should be able to look under the van at each wheel and see if there's a wetness from the brake fluid on the backing plate. If all wheels are dry then it probably time for a new master cylinder.
