Old 08-10-2010, 08:04 PM
hammer1755 hammer1755 is offline
1995 s10 blazer 4x4 transmission problem
transmission takes off in 2nd gear shifts into drive good and dont shift into overdrive.transmission guy replaced solenoids,didnt fix it,changed valve body didnt fix it,he said it might be the computer,does any one have any suggestions on what to check its got to be something electrical thanks
Old 08-11-2010, 11:50 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1995 s10 blazer 4x4 transmission problem
Might be does not get it.
Needs checked out on a transmission capable scanner to find the problems.
If any transmission or engine codes post back code no.
Does reverse work good?
Does it have 3 and od gears and are they working good?
Good 2-3 and 3-4 shifts and no slippage?
Was there any metal in pan when valve body changed?
MT
