Old 05-14-2003, 10:32 PM
riceriderjade's Avatar
riceriderjade riceriderjade is offline
stupid jade zc swap question
Allllright.
i know the only way to do a swap is to do it yourself
however i would fuck it up, the biggest thing i have done on my crx so far was put in a new rad.
i want to swap a zc into my crx dx. its auto and i wanna know what i'm looking to pay
a) for the engine and any and all parts
b) a shop to do the work
if you don't have the time to respond even a referance site would be great
thanks!
Old 05-14-2003, 10:58 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
well i got my ZC for about 560 shipped. When i was finished with my swap i had over 3000 in it. But that's because i rebuilt it from the bottom up, having all performance parts in. If you looking just to swap it straight in then i would at least replace the water pump, head gasket, and timing belt.... after the motor... you should be looking to spend about another $200 in parts to swap in.... I have no i dea what a shop would charge since i did mine myself.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 05-14-2003, 11:01 PM
88CRX's Avatar
88CRX 88CRX is offline
I payed $3000 Cdn for my dx auto to zc stick conversion.
That included....
-zc engine
-si tranny
-new axels
-timing belt
-water pump
-all other parts for dpfi to mpfi and auto swap
-all labour
-all misc fluids and stuff
zc powa
short ram intake
dc sports header
2.25 Magnaflow exhaust
h/r race springs
Old 05-15-2003, 01:05 AM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
Its pretty straight forward.
Check out the web site "the Zc resource"....not sure the exact address.
I DEFINETELY recommend changing:
Timing Belt
Water Pump
Head Gasket (if you have the $$)
You will need:
MPFI system.....
Si Harness
Resistor Box
Si ecu -pm6 (or 89 integ pg7, or Zc pm7)
Si Tranny
Si Axles
HEADER!!! Needs to be aftermarket, for 88-91 Si
I paid about $2000 total for my entire swap. But my car was already an Si, and I got a lot of other items like hoses and radiator, plus I needed a new trans. So, my motor and install was like $1500.
I definetely again will say to do the t-belt and the other items. Mine broke about 8months after install. Thank god nothing got f-ed up in the head. Just remember that the motor only has about 30k miles on it, but it is also 11-13 years old, so it will need some work.
Old 05-15-2003, 01:11 AM
GTA's Avatar
GTA GTA is offline
Whee..
www.thezcr.com
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 05-15-2003, 01:12 AM
88CRX's Avatar
you dont need a header.
zc powa
short ram intake
dc sports header
h/r race springs
Old 05-15-2003, 08:57 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
Right...and also..the "correct" header is a 89 integra top half which already has the ports to match the ZC, and a 90-91 Civic bottom half so that it matches up with the cat. Except I don't know anyone that wants to buy two two-piece header systems to create the correct one, so most people get the 88-91 header and match the ports with a little grinding on the header
Good Luck with whatever you decide.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 05-15-2003, 09:13 AM
88CRX i could kiss you, i have an 89 auto dx so your numbers are probably what i'm looking at paying and thats doesn't seem like too bad a price. how old was your zc? how many k?
thanks everyone
Old 05-15-2003, 12:43 PM
88CRX's Avatar
dont know how many kms'? they say under 30k but who knows. oh ya make sure you get some sort of warantee in writing or a compression test done.
zc powa
short ram intake
dc sports header
h/r race springs
Old 05-15-2003, 12:47 PM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
i got my sohc ZC for about 250 and installed with a new radiator which rang me 150 for 900.
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
Old 05-15-2003, 01:01 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
I just did my ZC swap. If anyone know the immense problems that can go wrong it's me, and I know how to fix most of them.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 05-15-2003, 03:13 PM
Dark Syde Racer Dark Syde Racer is offline
things you will prob. have to pick up..are as follows
TPS (go to a junk yard and pocket a few)
SI throttle cable (just because the dx tends to hang up because its longer)
always safe getting a new water pump/HG/timing belt
New Clutch (im running a ACT 4 Puck on a 89 Si regeared tranny, and if your doing the clutch you might as well do it right..get the flywheel turned..or lightened for that matter)
you might need a teg rad. hose (might)
now since your going from a DX (as i did) you will need to do a new wireharness and run a good ECU (pm7 or pg7)...thats the hardest part of the swap is the harness....other than that..it bolts right up to your stock motor mounts....
1990 GS-T
Mods:
HKS intake
16G turbo (18psi)
ALL FREE MODS
full 2.5 exhaust
S-AFC controller
HKS turbo timer
HKS ECV II
3in Custom intake pipe
Chipped ecu
short shifter
Cyclone motor
5.6 LCD screen
PS2/DVD player
Eclipse CD player
JBL speakers
Fosgate HX2 12
1991 GS-T (NEW PROJECT)
2.7 to 3.2 Engine Swap Question ddennis002 Intrepid 1 12-01-2010 07:15 AM
Help with trans/diff fluid swaps... stupid procedural/tool questions (PICS) Cobra4B GTRA / GTWS / GTS 2 01-23-2008 12:03 AM
Another stupid Hayabusa/Ninja question Gafoto Street Bikes 4 11-20-2003 06:39 PM
Stupid grand prix question LancasterWannaBe Grand Prix 1 07-01-2003 06:36 PM
stupid power steering question 1 bill w Engineering/ Technical 1 03-25-2003 06:41 PM
