Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-09-2010, 06:33 PM
I_sell_fast I_sell_fast is offline
Need Help Badly with my 97 Eclipse gst!!!
Ok so here it is. I have a 97 Eclipse GST. My mass air flow sensore was gross as can be so i cleaned it then when i took it out for a test drive the front motor mount decided to go out. So i replaced it and took it for a test drive but had a little lag in 1st and 2nd befor the car moves and then in 3rd im siting there with the gas pedal on the floor and not moving then all the suden the car takes off. I have new plugs and wires, new fuel filter. I cant figure out what is going on. Any help would be apriciated
Old 08-11-2010, 01:55 PM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
Re: Need Help Badly with my 97 Eclipse gst!!!
Did you reset the Ecu after you reinstalled the MAF?
If not I suggest you unhook your battery and allow it to sit for a bit.
The MAF can cause all sorts of problems, so look into it
Old 08-12-2010, 08:21 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
How did you clean the MAF?
Kris
2012 Genesis Coupe 2.0t
