Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 08-09-2010, 01:26 PM
rfpoil rfpoil is offline
Send a message via Yahoo to rfpoil
2006 sonata air question
hi what should my pressure readings be for my manifold gauge for a 2006 sonata 3.3
its 90 degree outside and Humidity 70% . My air compressor cycles on and off to much and the air inside is warm 1 minute and then cold, after running for while it stays cold. would like some help on this 1 .
thank you
Rob
www.rfpoil.com
Old 08-19-2010, 06:37 PM
Bear Bear is offline
Re: 2006 sonata air question
I would like to see about 34 PSI low and 225 High on the gauges.
Old 03-25-2011, 06:10 PM
thepeggasus thepeggasus is offline
Question Re: 2006 sonata air question
I also have a 2006 Sonata air question. I can't find where to post a new thread in the upper right corner as the guide says or anywhere else. The AC fuse under the hood kept blowing and at first would work for a day or two when I replaced the fuse. After a week or so, they would blow immediately. I assumed that it was a shorted wire somewhere between the fuse block and the AC compressor. I ran a new wire straight to the AC compressor and it worked - for about five minutes and the fuse blew again. None of the other controls seem to be affected, there is power without any problem all the way to the fuse block and I replaced the wire with 14 gauge to the compressor. What could be causing this? Stumped!!!
Old 03-26-2011, 10:30 AM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
I'm thinking it's the field coil on the compressor. We used to replace those all the time years ago. Not so much any more. Check the resistance between the field coil connector and the compressor housing. Should be 3-4 ohms.
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
The Following User Says Thank You to lowsonoma1999 For This Useful Post:
thepeggasus (03-27-2011)
Old 03-27-2011, 01:40 PM
Thanks! I'll check that.
Just a footnote, I tried it one more time. Before the fuse blew, the system vented. I found that if I ran the AC for 30 seconds, cut it off for 30 and repeated that cycle, the AC would run and also not blow the fuse. Is there a sensor that registers head pressure and cuts off the compressor when it builds up? I'm afraid AC systems are not in any area of expertise on my part.
Thanks again!!
