Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 08-09-2010, 11:41 AM
jwalker1970's Avatar
jwalker1970 jwalker1970 is offline
1999 Bonneville SSEi fog lamp relay location
I have a 99 Bonneville with fog lamps stuck on. I removed the fuse (6D 15A) in the under column fusebox, and the lamps go off. replacing the fuse, the lights come back on, even with ignition off. I disconnect the battery, when re-connected relay is still stuck on.
Where is the Fog Lamp Relay??
It's Not: in the relay bank in the engine compartment on the firewall below the fuse panel.
Thank you in advance for your help!
Old 08-10-2010, 08:09 PM
Mickey#1 Mickey#1 is offline
Re: 1999 Bonneville SSEi fog lamp relay location
Under the dash on the passenger side. Should be the lowest relay, position A.
