Old 08-09-2010, 05:55 AM
spalko004 spalko004 is offline
95 lx wagon wont start
my 95 wagon lx was running smooth til last tuesday i was cruising along hiway and it just suddenly stalls? i had it towed... i did replaced the plugs, fuel filter. it cranks but it wont start? i even replace the injectors...
Old 08-09-2010, 09:17 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: 95 lx wagon wont start
May be a broken timing belt.
Nevada Tumbleweed
Old 08-10-2010, 12:05 PM
FordMan59 FordMan59 is offline
My guess would be either the timing belt or a fuel pump. When you turn the ignition switch to the on position can you hear the fuel pump run for about 1-2 seconds?
Old 08-12-2010, 12:44 PM
Davescort97 Davescort97 is offline
Escort guy
I'm thinking the timing belt, also. You can check it for being broken by taking the oil filter cap off of the top of the engne. Have someone turn it over while you look for the valve train movement. No movement. Broken belt.
Tags
problem , starting
