Old 08-08-2010, 11:00 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Bigger Alternator
I'm looking to see if anybody has put the optional 130amp alternator on over the 105 amp. I want run electric fans and fog lights and maybe some subs in the future and dont want to burn up and get stranded. What I want to know is does the 130 bolt up the same? Do I need a bigger battery? Bigger positive cable? Connectors the same? Any insight would be great. Thanks Tim
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 08-09-2010, 08:49 AM
j cAT j cAT is offline
Re: Bigger Alternator
the AD130 or the AD105 use the same frame. these new alternators made now can be had with a lifetime warrantee autozone. they are updated with changes made that caused the older versions to fail due to the regulator getting corroded.
adding cooling fans and high powered noise making equiptment will cause the 130amp to get overloaded ..your vehicle uses 65amps normally ..20% safety factor on amps load factor ..
you must have a capacitor at the power amp to control surges ..
Old 08-09-2010, 11:56 AM
kahjdh's Avatar
The subs will be small, maybe one 12". My main worry is the fans and foglights. I drive backroads and high beams dont cut it, I was looking at some KC daylighters to put on my brushguard. Also thinking about the high and low beam conversion but worried about overloading the factory wiring harness....
Current Cars:
Past Cars:
Old 08-09-2010, 12:40 PM
if you need more light power on these back roads , install powerful lamps with your own relay and control switch. do not mess with the existing lamps. to replace these lamps/lenses is very expensive and must also be legal. with the lamps I am taking about , you should have no problem seeing ..air craft landing lights work best.
Old 08-09-2010, 08:44 PM
someday31 someday31 is offline
I have the 130amp in my truck. bolts right in, no changes necessary. I dont have high powered lights though so probably dont come close to maxxing the alternator out. I have a sealed box alternator like this DLG1923-16-4 from autozone if you are interested. It is 2 months old, never opened. Its brand new too, not a rebuilt. Message me if interested.
