Old 08-08-2010, 04:08 PM
laxman21's Avatar
laxman21 laxman21 is offline
Assembly directions please
Hoe do you put this on correctly?
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 08-08-2010, 08:27 PM
laxman21's Avatar
Re: Assembly directions please
Figured it out.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 08-08-2010, 08:42 PM
old_master's Avatar
Advisor/Moderator
You got all but one thing: the nut goes on the bottom so it doesn't interfere with the tie rod over bumps and while turning. Might want to tighten it up a little more too, the insulators should be a little more "squashed". Other than that, good job!
You have to know how it works,
to figure out why it doesn't.
Old 08-10-2010, 05:55 PM
laxman21's Avatar
Did the other side
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 08-10-2010, 11:06 PM
old_master's Avatar
Advisor/Moderator
There ya go, good job!
Old 08-11-2010, 09:27 AM
laxman21's Avatar
So, they look squashed enough or too much? Suspension feels tighter(maybe a little stiffer, could just be mental) and the popping noise I use to hear while backing up and turning the wheel sharply seems to be gone.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 08-11-2010, 05:01 PM
old_master's Avatar
Advisor/Moderator
They look fine, although the upper insulator on the driver side looks like it might be off-center a bit.... might just be the picture. When tightening the nuts, the wheels should be on the ground to avoid misalignment of the insulators, and to keep stress to a minimum. The insulators have a "shoulder" that needs to be centered in the sway bar and in the mount on the lower control arm. If the bolt comes in contact with the mount or the sway bar, you'll hear, or feel it, when your driving.
