Old 08-08-2010, 08:52 AM
lazeit lazeit is offline
ABS LIGHT Stays On
Hi - I have a 99 SEL with 125k and the ABS light is on all the time. I have filled the resivor, cleaned the wheel sensors with brake cleaner and sanded the sensore rings with no avail. When I did the back sensore the light wnet off for abour .5 a mile but is back on full time regardsles of if the van is moving. Thoughts?
Old 08-08-2010, 10:55 AM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: ABS LIGHT Stays On
Hello and welcome to the forum!
Do you have any other problems on your windstar? Like cruise control not engaging, odometer or speedometer problems or the Brake like staying on too?. Just to make sure take a quick look at the brake pressure switch, it is known to be defective and ford has issued a recall on these models. Here's a link to the thread with info about it.
http://www.automotiveforums.com/vbul...d.php?t=681061
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 08-08-2010, 11:17 AM
I just went and drove to confrim the crusie works and it does.
Old 08-08-2010, 11:24 AM
And I see no problems with the speedo or brake light.
Old 08-08-2010, 07:50 PM
olopezm's Avatar
Have you experienced any humming sound while driving at a moderate speed? Maybe the wheel hub bearing is bad. Also when you replaced the sensor did you check the wiring for any cracks on the shielding?.
Old 08-09-2010, 06:31 PM
Seizer's Avatar
Seizer Seizer is offline
I am right there with you lazeit. Mine has been on for about three solid years now. In winter time it goes away and have come to believe its the ABS computer being crap.
http://www.fordwindstarrecall.info/
Just had the recall done 09S09 that deals with leaking brake fluid causing a fire and of course I still have the problem along with a low tire pressure warning now too. ~grrrr~
Old 08-19-2010, 12:34 AM
AvalonJohn AvalonJohn is offline
Mines been on for 8 yrs.
Old 08-28-2010, 08:21 PM
We just picked up the Windstar from the dealer after pointing out the brake reacl and all they did was replace the wiring harness. ABS light i still on and ABS dosen't funtion.
