Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 08-07-2010, 05:39 PM
Miguelg916 Miguelg916 is offline
01 Civic A/C Problems
Ok know, got an 01 civic and my A/C is giving me poblems. It works and blows extremely cold air, however when I make left turns and left turns only, my right side vents cut out for a few seconds. It sounds like something is in the vents but I found nothing. Also I have water seaping in from the A/C ventilation tubes uder the dash. The water doesn't make it all the way through just at the passengers feet. Does any body else have this goin on or have an Idea of how to fix it. Please let me know. Thanks
Old 08-09-2010, 10:09 AM
Copytech99 Copytech99 is offline
Re: 01 Civic A/C Problems
Your vent tube that exits under the car may be plugged and the water off the evaporator could be backing up and flowing inside the system and the cabin.
When you run your A/C you should get water dripping underneath the car if the drain is working correctly.
Old 08-11-2010, 07:11 PM
BullShifter's Avatar
I would blow some air in the drain tube. You can remove the cabin filter to try in look in there.
Old 09-01-2010, 09:30 AM
Cool, Thanks guys. This was really gettin on my nerves.
