Old 08-07-2010, 12:29 AM
phewop118 phewop118 is offline
Intermittent SVS Light
Alright now here's a weird one. Lately, after about 10 min of driving after a cold start, the engine quickly cuts out for less than a second and it feels like the brakes are briefly
applied. About 10% of the time, the SVS, trac off, and pcs lights then turn on until I restart the car. Could this be a failing wheel speed sensor? Or am I looking at a controller somewhere. I doubt it's the abs pack, as the abs still works. I know this is hard to diagnose over the Internet without codes, but I was wondering if anybody has
seen something like this before. It can happen while cruising or even while accelerating hard and it happens only once after a cold start. The engine is fully warmed up by this time, too.
Current Cars:
2001 Oldsmobile Intrigue GLS 154k miles
2005 Chevy Trailblazer EXT LT V8 145k miles
2005 GMC Yukon XL SLT w/Autoride 86k miles
2007 Pontiac Grand Prix GT 77k miles
2007 Cadillac DTS Lux II 47k miles
In Limbo:
2003 Oldsmobile Aurora 4.0 - got side swiped while parked, waiting on insurance decision
Recent Past:
2007 Hummer H3 5-speed Lease was over 7/17/10
Old 08-07-2010, 06:18 PM
carbon02 carbon02 is offline
Re: Intermittent SVS Light
Wheel speed sensor, or the Brake control module. Krivasauto also addresses this on his site.. http://99intrigue.shutterfly.com. I think it's called EBCM.. Electronic Brake control module.
If this occured after you went though high water I'd suspect wheel speed sensors are the issue.
2002 Oldsmobile Intrigue, 3.5L, GX --121,000 Miles as of 2/4/2011
2000 Oldsmobile Intrigue, 3.5L, GX --81,000 Miles sitting in garage awaiting shift kit P1811, and potential water crossover gasket repair.
Old 08-08-2010, 11:42 AM
I should clarify that it has been doing this since before I drove thru water. Also, I am leaning away from the EBTCM, as the ABS light would usually come on if that was the case.
Current Cars:
In Limbo:
Recent Past:
Old 08-09-2010, 01:24 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
First thing I would do is pull all the connections for the wheel speed sensors, maybe get some electronics cleaner and spray in them, then reseat the connections.
I have seen this many times, my Intrigue sees a lot of gravel roads and therefore dust, which makes for poor electrical connections. Usually a little connection fiddling makes everything as it should be.
Also Ive noticed the sensor wiring harnesses occasionally fall off their little clips (it makes more sense when you see them) anyway they start flopping around, which can trigger and error. Had this problem a lot, finally zip-tied the stupid things onto the clips.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-14-2010, 10:49 PM
I have seen the svs light and all accompanying other ones before on gravel roads too. But usually they go out after restarting. Today when I started the car (first time in a week) the svs, pcs, trac off, and antilock lights were on immediately. Restarted and same thing. Never seen the antilock light on before. Magnasteer was also disabled and the steering was at highest effort level. After driving 25 miles and then restarting, the lights are all off. Another new thing happened last week. I was idlin in a parking spot about 10 min after cold start and the engine actually shut off and the lights came on. Restarted and it was fine.
I'm beginning to think a trip to the dealer is needed to scan for abs codes. Just wondering, do those codes keep in history like engine codes? Or do they vanish when the light shuts off?
Current Cars:
In Limbo:
Recent Past:
Old 06-20-2011, 05:43 PM
I know this is nearly a year later, but the prev problem was fixed with a new rear right hub (wheelspeed sensor failure). This was done ~7 months ago.
Now, I have a new issue with the same lights illuminated (and addition of ABS and BRAKE). The following lights are on about every other ignition cycle: SVS, ABS, Brake, TCS OFF, PCS. In addition, the Magnasteer is not operating - requires more effort at parking lot speeds now.
I was worried when I saw the 'brake' light on that the fluid might be low, so I took to get scanned at the dealer. The EBCM has failed. Any suggestion? The part is $900 new, which is probably more than the car is worth. Anyone have luck getting one on ebay? or junkyard?
Current Cars:
In Limbo:
Recent Past:
Old 06-21-2011, 12:12 AM
sparcx sparcx is offline
i would like to say that Modulemaster was the recommended company for the repair on this part. do a search in the intrigue forums and a few threads will probably pop up.
Tags
engine , svs , traction
