Old 08-06-2010, 09:52 PM
nancy wright nancy wright is offline
voyager
Hi, I have a 1998 plymouth voyager. I just bought it, When I got it I was having issues with the alarm. I got that problem solved. Now, sometimes the dashboard gages will not work at all. I hit the dashboard and they worked for a minute. now my van won't start. I just got a new battery, and new cables. I know its not the battery, cause all the lights, and radio work. it just won't turn over, and sometimes the windows won't go down. its all power. Any solutions?
Nancy Wright
Old 08-07-2010, 03:10 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: voyager
Sounds like a typical instrument cluster solder joint issue. Here's how to gain access to the instrument cluster and fix it. All you need are basic tools, a soldering iron and a bit of solder: Open "98t&c dash removal" low in right column then click slideshow at upper right:http://www.flickr.com/photos/landar/
With age the solder joints on the instrument cluster circuit board connector crack opening the data bus circuit, killing the instrument cluster and starting. An all too common problem.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
