Go Back   Automotive Forums Car Chat > Ford > Probe
Old 08-06-2010, 06:45 PM
pepp pepp is offline
AF Premium User
popping ?
Hey guys, I need some help here with my timming, can some one walk me thrue the steps on how 2 check timeing belt , & fireing order, dist was out . thanks in adv. 1992 2.2 12v none turbo.
Old 09-11-2010, 07:50 AM
rhandwor rhandwor is offline
Re: popping ?
Your best bet is purchase a Haynes manual or go to library. You need a copy when checking plug wiring diagram.
Was the distributor installed correctly you need engine on top dead center and rotor at Number one plug.
Belt engine at top dead center,cam lined up on mark if dual both cams need lined up to mark. Some Japanese engines oil pump also needs lined up.
Best to rotate to top dead center before removing belt,rotor at number one. Check and mark all pulley marks use a Hi Liter. Use white out and mark distributor rotor and side of distributor before removing.
