Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-04-2010, 05:15 PM
bikechuck bikechuck is offline
98 t/c blend door motor keeps turning
trying to replace blend door motor (top side) on 98 towncar. ATC. Before reassembling I plugged the new motor into the harness and fired up the vehicle and AC. Previously it blew only heat. Self test indicated 24.Motor started turning and never stopped as if it was looking for home positition. Self test still indicates 24. Old motor does the same thing. Do I have a control module problem? From the looks of the motor its only supposed to rotate 90 degrees and has a built in position indicator, rheostat wiper. This really is one tough job working through the glove box door. thanks.
Old 09-04-2010, 04:37 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: 98 t/c blend door motor keeps turning
if the motor was out of the case when you turned it on it is junk. you need to have it mounted for the search. it can then find the door travel.
-=-=-DANE-=-=-
