Old 05-14-2003, 07:02 PM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
Wicked Vibration.
Okay today coming home from school, I started getting this violent vibration in the engine part of my car. violent enough at times to make my cd play skip. At first I thought it was a flat tire, but they are good and pumped. So when I got home I had some friends look at it, and they said it might be the timing belt. Now would a loose timing belt cause this type of vibration?
PeacE
Old 05-14-2003, 07:51 PM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
my car did this for a lil bit, it would shake and pull to the sides
i ended up needing outter tierods and alignment
the front right wheel would shake back and forth
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
Old 05-14-2003, 09:15 PM
chopstick1981 chopstick1981 is offline
it wouldn't be the timing belt unless its so loose it skipped a tooth on the belt, but you could really tell then, cuz it wouldn't idle well either.
Old 05-14-2003, 09:26 PM
Stali08's Avatar
Well i guess i should of added that when i press on the gas its like the engine just kinda skips and wont really speed up. So its really hard for me to gain speed.
PeacE
Old 05-14-2003, 09:37 PM
i had probs like that about a year ago. try puttin a screwdriver up against the distributor while its runnin and put your ear on the screwdriver, listen for grinding sounds coming from in there
Old 05-14-2003, 10:27 PM
Stali08's Avatar
Would the type of gas i put in do it? Becuase i put in Sonoco gas yesterday and today it acted up because their gas has ethenyl in it, so clogged fuel injectors? Dad said about dry gas or fuel injector cleaner. Anyone have this problem before?
PeacE
2003 e150 vibration sound when accelerating webpage1111 Econoline 0 07-13-2010 12:50 PM
Vibrations / sound at high speed Elias125 Engineering/ Technical 5 05-19-2010 05:05 PM
Vibration at high speeds uspres2020 Grand AM 4 07-19-2009 06:23 PM
1990 right front driveline vibration dieter LeSabre 2 04-04-2009 08:16 PM
