Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-03-2010, 01:25 PM   #1
fred fred
1999 Mustange ABS Brakes Spungy!!!
I Changed the front Disks, Pads, & Calibers. Lost all Fluid while doing this.
refilled it, Have been trying to bleed since last night. No luck. Any ideas.
Fred
fred fred is offline   Reply With Quote
Old 08-03-2010, 01:55 PM   #2
Franco2112
Re: 1999 Mustange ABS Brakes Spungy!!!
You have to bleed all brake lines. Front brakes and rears all sides. This should fix it.
Franco
Franco2112 is offline   Reply With Quote
Old 08-03-2010, 02:04 PM   #3
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
If you let the reservoir run dry, you need to bleed the ABS system using a computer that can command it. In other words, you have to go to the dealer to bleed the ABS system.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
Old 08-03-2010, 02:05 PM   #4
fred fred
THanks I hope this dose it.
