Old 08-03-2010, 07:00 AM
SulkierLizard SulkierLizard is offline
Bought new radiator. Plastic cracked. Is this okay?
So I bought a new radiator for my Jeep 2000 Cherokee 4.0L. It developed a crack and my mechanic told me that it's better to replace it. This radiator has close to 200,000 miles on it anyway so I decided to buy a new radiator from autopartexpress since it was WAY cheaper than autozone and anywhere else.
http://www.autopartsexpress.com/sear...lookfor=CU2340
Anyway, it arrived yesterday and I noticed the plastic was broken on it. Is this safe to use or should I return it? Here are some pictures so you can see what I am talking about. You can only really see that it is broken in the first picture. It's just broken underneath that plastic piece that turns. I believe it's called the petcock and allows you to drain the radiator? How can I check to see if it's okay to use? Thank you.
Old 08-03-2010, 08:27 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Bought new radiator. Plastic cracked. Is this okay?
It might be ok...I'd remove the petcock and use a magnifying glass to look around the area where it screws in. If the crack is just on that ring around the petcock, it's probably ok but if the crack extends to where the petcock screws in, then it's going to leak.
Hopefully you have some sort of return available to you; so if you're not sure, send it back.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-03-2010, 09:26 AM
2000izusu 2000izusu is offline
i would send it back.
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 08-03-2010, 11:01 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Yup, Id send it back also. Or at least call them and tell them what the deal is and see what they want to do.
Old 08-03-2010, 12:39 PM
Saudade's Avatar
Saudade Saudade is offline
Is yours a RHD? I would return it as well. If you can, get an all metal one.
Dad's taxi:
'88 XJ - 190K and going strong.
K&N, Ford Injectors, No other mods
Old 08-12-2010, 09:54 AM
Returned it and got an all metal LHD at Advance. Thanks for the embarrassing heads up. Installed it myself and it works great!
