Go Back   Automotive Forums Car Chat > Ford > Freestyle
Old 08-02-2010, 09:26 PM
marksieja marksieja is offline
Speedometer instrument cluster going to zero
I have an early model 2005 Freestyle SEL. I am having problems with the speedometer / insturment cluster going to zero, because of a bad circuit board. Ford Service Bulletin TSB 06-17-9. Rather than spend the $380 for a new Ford replacement part, I have found several on E-Bay. Does anyone know if the Limited model instrument cluster cable connection is compatible with the SEL connector.
Old 09-04-2010, 04:02 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: Speedometer instrument cluster going to zero
the connectors are the same however you will still need a dealership to install the I/C. it is a programmable module!
-=-=-DANE-=-=-
