Old 08-02-2010, 07:16 PM
houndog3 houndog3 is offline
Transmission Temps temp Gauge
i got a 1997 4x4 350ci . I would like to put a trans temp gauge on it. my question is, where do intall the sending unit at? I have not bought a gauge kit yet i would love to here some suggestion on what kind to buy..I dont want to spend no more than a 100.00. nothin fancy just a good one,..thx jeff
Old 08-03-2010, 11:07 AM
Bob B Bob B is offline
Re: Transmission Temps temp Gauge
I added one to my 97 and shopped around some.
Most that were shown to me had the numbers too compressed to read easily.
But I discovered the one from B&M at a speed shop.
It was not expensive, and easy to read, color coded face makes it even easier.
BTW B&M is the tranny build up specialists.
Bob B
Old 08-03-2010, 11:33 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Most work good when installed into the transmission oil pan.
Just be sure you miss the filter and valve body and solenoids and wiring when you install in
the pan.
The transmission also has a built in temperature sensor to VCM that could be tapped or temperature read out with a transmission/engine capable scanner.
MT
Old 08-03-2010, 03:42 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
For the 4L60E transmission, there is a fluid pressure test port located on the driver's side just above and in front of the shift linkage, plugged with a 1/8" NPT plug. The temperature sender can screw right in there. Although putting it into the pan would let you use it as a drain plug, you'd have to weld in a bung for it...not an option for most of us shadetree mechs.
Most gauges are in the $50-$70 range. Pep Boys has the cheapest by SunPro @ $40 for a basic black 1/4-sweep face. I had bought it and a silver/white 1/4 sweep Autometer Pro Comp gauge for $55 but ended up returning the SunPro because it appeared that one's sender went in deeper into the tranny case than the Autometer's. I didn't want to risk it hitting anything inside and could find no docs as to what was the allowable depth limit, so I played it safe.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-03-2010, 05:34 PM
I went to a 4x4 shop and i was talking to the parts man,he said the best way is to get your temp reading off the return line from the cooler,is this true?? He recommened a B&M and you cut the low pressure side and go from there!! he claimed that by having the sending unit mounted in the xmission case i would get erractic readings from the touque converter heating up and cooling down..he claimed it would drive me nut!!! thx for any more in put please...jeff
