Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 08-01-2010, 09:26 PM
goldiemyear goldiemyear is offline
water pump replacement
Does anyone know the proper maintenance schedule for the Aveo water pump? My 07 has nearly 120k on it and will soon be replacing the timing belt again. The manual only recomends the belt every 60k and the coolant at 150k. Any known problems with the Aveo water pumps? Need to decide if I should just replace it and the coolant early at 120k or run the risk it will make 180k. Any ideas out there?
Old 08-04-2010, 03:03 AM
Davescort97 Davescort97 is offline
Escort guy
Re: water pump replacement
Replace the pump at 120k. I don't think it will last until 180k. Besides if it breaks it'll break the belt which in turn will destroy the engine.
Old 10-19-2010, 09:54 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
I work at a Chevrolet Dealership and I would say to get the water pump replaced. It is easier to do it now. this way you will not have to make two trues and you will save a bunch on labor costs. You will not have to pay twice for the work. Just once and parts.
Old 10-22-2010, 09:08 AM
mcthumber mcthumber is offline
+1
Everything is torn down for the belt replacement, doing the WP at the same time is short money. You're actually pretty lucky the 1st pump went to 120k!
Old 10-23-2010, 07:25 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
As said very good time to replace it.
Might be interesting to ask your parts people how many water pumps they sell for them.
Most good parts people can look that up on there computer.
Go brand new over a rebuilt water pump.
On the GM coolant I always like to service it every 3 years or 50K.
Good Luck
MT
Old 12-14-2010, 03:26 PM
slayerwesco slayerwesco is offline
also it will not hurt engine if you time it wrong or if bel t breaks. is a non interference engine!
Old 12-14-2010, 03:33 PM
This is incorrect.
Old 12-14-2010, 06:19 PM
MT-2500's Avatar
AF - Advisor
Originally Posted by mcthumber View Post
This is incorrect.
I will second on it is incorrect.
Go here and go down 1/2 way and click on got interface engine.
http://www.gates.com/brochure.cfm?br...reset1073Gates
MT
Old 12-15-2010, 09:38 PM
Very important to keep up with the maintenance. This motor is a zero tolerance motor. You can be ONLY be one tooth off and the motor will run rough, but any more and it will damage the motor internally.
