Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 08-01-2010, 01:08 PM
hotpipes hotpipes is offline
rust just below tank fill up door
Has any one experienced rust showing up just below the gas fill door? I sand blasted it and then painted it and rubbed it out and the rust came back. Is this a defect in the metal or design of the 2002 Malibu sedan?
hotpipes
Old 08-02-2010, 08:25 AM
Jetex Jetex is offline
Re: rust just below tank fill up door
I would look up into the rear wheel well behind the gas fill door. Maybe the splash guard has a problem and salt has caused the rust and penetrated to the surface. Not sure what the 2002 Malibu looks like up there though.
Old 08-03-2010, 06:36 AM
I will get back to you as soon as I check that out. Thanks jettex
Old 08-04-2010, 05:09 AM
Here is a tip about underbody rust. If you see rust, clean it off - a wire brush works well. Spray the cleaned area with an asphalt based pruning sealer available in aerosol cans. When the first coat dries spray again until a nice thick layer is deposited. I got the idea from the instructions on the aerosol can that said I could repair leaky gutters with it. So far it works just great.
Old 08-16-2010, 05:28 PM
msliva msliva is offline
I have this problem on my 2002 Malibu. I haven't done anything about it and it's starting to spread out. I think the rust is starting from the inside out.
Old 08-16-2010, 07:22 PM
msliva
I have checked on the underside of the fender and it feels like there is a second skin of metal under the outer skin of metal. It feels like a raised section on the inside that could be trapping water. I'm not sure weather to drill a hole in this area to let water drain out when it gets trapped or would i make the problem worse by letting more water in? I sure could use some help with this problem.
hotpipes
Old 08-17-2010, 09:56 PM
Johnny R Johnny R is offline
There is already a drain hole in the gas cap filler area. Drilling a hole in the backside would not help, but would likely be a winter salt trap.
Johnny R.
2011 Malibu LT - It's a beaut. So was my '99!
2006 GoldWing 1800 cc - the way to go, coast to coast!
Old 09-02-2010, 07:27 AM
pauly99 pauly99 is offline
Bizarre in that I have the same exact problem. It is about a 2" by 3" area just below the gas cap. Told myself that I would fix it once spring came.. um er and I should take care of it now and get some paint (from where?) before it gets any worse.
Old 09-02-2010, 08:48 AM
pauly99
This is where I got my Paint from and it was a good match. I was lucky enough to find a store in my home town check there store locater you may have a store near you. http://www.sherwin-automotive.com/
hotpipes
Old 09-21-2010, 12:54 AM
Bill60118 Bill60118 is offline
I have the same problem on my '01 Malibu. I thought it what possible gas drips from removing nozzle that caused the problem.
Old 09-01-2011, 12:35 PM
Originally Posted by hotpipes View Post
pauly99
hotpipes
I found the rubber padding between the inner and outer skin by grinding more outer body skin off. I can not take all of the rubber out because it is sandwiched between the inner and out skin of the entire wheel well but I got out as much as i could reach and the back side of the outer skin is coated with rust there is an area around the gas fill pipe that is without the inner skin and I can see the rubber sticking out
Do you think it would help to cut off the rubber sticking out and silicone over that seam or just under coat it? I will use the rust neutralizer before I close it up. Which brings me to another question. The hole is 3" by 6" would you use fiberglass cloth or pop rivet a peace of metal over the hole. The inner skin can and will support the mud if that is the way to go with this repair.
hotpipes
Old 11-17-2012, 08:13 AM
After using fiberglass on the outside under the fill pipe I than used bondo to finish off the outside of the fender patch made of sheet metal and then I under coated the underside of fender around the fill tube and that has solved my problem.
hotpipes[/quote][
