Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 07-31-2010, 08:00 PM
JasonF JasonF is offline
Starting issues when hot...help please.
Hey all, new here.
1995 Delta 88, car runs and drives fine when cool, but when it's at normal operating temps, turn car off, it won't restart unless it sits for some time, usually 30-45 minute +. It will try to start, and run, but very poorly, almost like it's dieseling sometimes, and others it'll just crank. As per suggested by some mechanic friends, I've replaced the coil packs, ignition module, and coolant temperature sensor, yet the problem still presents itself. I tested the fuel pressure and it's fine as well.
Any other ideas?
Thanks!
Old 08-01-2010, 09:35 AM
maxwedge maxwedge is offline
A990 racer
Re: Starting issues when hot...help please.
Welcome to AF. See if there is raw fuel in the vacuum hose at the fp regulator when this happens.
Old 08-01-2010, 11:53 AM
Thanks for the reply!
Where would that be located?
Old 08-01-2010, 01:05 PM
A990 racer
The regulator is on the fuel rail you will see a vacuum hose on it.
Old 08-01-2010, 04:13 PM
I gotcha. That small L hose correct?
Old 08-01-2010, 07:14 PM
A990 racer
Yes. Look for raw fuel in the hose after a short hot soak.
Old 08-02-2010, 10:31 PM
Well I've checked a few times. Before, during, and after the issue and haven't seen any raw fuel. If I do happen to, what would I be looking at for a fix? And can you think of anything else it could be?
Old 08-03-2010, 07:56 AM
A990 racer
The press. regulator would be bad if raw fuel. When it won't start you must check for good blue spark at the plugs and proper fuel pressure at the rail, you could also try disconnecting the maf when this happens.
Old 08-07-2010, 10:22 AM
tsutton123 tsutton123 is offline
I had the same problem with my 1992 delta 88 it was a vacuum leak.
