Old 07-31-2010, 07:53 PM
dcmaker100 dcmaker100 is offline
no cruise 97 lesabre
how do i trouble shoot my cc.so far i checked the fuse.
Old 07-31-2010, 09:14 PM
happydog500 happydog500 is offline
Re: no cruise 97 lesabre
I just fixed mine, When you turn on Cruse, and push the button, does the "cruse" light come on?
It can be the switch on the brake peddle. I figured out mine was not the problem because my Cruse light came on. When I pushed the brake, the light went off. That told me the Brake Switch was working.
Remember, a brake light out can supposedly make the cruse not work, so check the brake light(s).
Does the "Cruse" Light come on the dash when you engage cruse?
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 08-01-2010, 07:36 AM
imidazol97 imidazol97 is offline
AF -Advisor
I may remember wrong, but if the center brake lights are out that turns off the cruise. Check the lights in the rear window when the brakes are on...
Old 08-02-2010, 01:11 PM
thanx for your response.all brake lights are working including the center one.There is no dash light coming on to let me know the cruise is on when i slide the lever on the directional to the middle or on position.
Old 08-02-2010, 08:52 PM
Sliding the lever over to the middle or end does not turn on cruse. You have to push the button in when you have the lever in the on position.
New Balance 662
Trek 8000
Old 08-03-2010, 09:29 PM
nothing happens when i push the button.no lights and no cruise control going down the road.
Old 08-04-2010, 08:06 PM
First lay down and look up at the break lever, where it touches the switch. Make sure it's making contact enough to switch the switch.
Chris.
New Balance 662
Trek 8000
Old 08-06-2010, 12:03 PM
yes it appears to compress the switch all the way.
Old 08-08-2010, 09:21 PM
Thumbs up Re: no cruise 97 lesabre
fixed.the problem was the control unit on the firewall w/ the cable to the throttle.replaced with one from a pic n pull.
Old 08-10-2010, 06:03 PM
That was my next post. That's how I fixed mine.
Chris.
New Balance 662
Trek 8000
Old 08-11-2010, 07:08 AM
THANX FOR POSTING HAPPYDOG.i APPRECIATE ANY HELP I CAN GET.
Old 08-12-2010, 03:39 PM
Your welcome. Sorry for the delay in responding to each post, I was jammed with stuff and had to put the internet on the back burner.
Chris.
New Balance 662
Trek 8000
