Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-31-2010, 11:55 AM
onerobertone onerobertone is offline
EGR clean the large hole that supplies exhaust flow
I just cleaned the vacuum port on my 2001 rodeo EGR. I would have liked to have cleaned the large hole that supplies exhaust flow for reducing the oil consumption problem - but I can't find anything about it.
Does anyone know the link is or how to do it?
Old 07-31-2010, 07:29 PM
Cat Fuzz Cat Fuzz is offline
Re: EGR clean the large hole that supplies exhaust flow
Cleaning the EGR passage, while being a good idea to do, won't effect oil consumption. Oil consumption is caused by a design flaw with the pistons. Not enough drain back holes allows oil to push past the rings. To clean the EGR passage, remove the EGR valve, 2 small bolts. The most common place for the passage to plug up is in the intake where it dumps out. The tube coming from the exhaust rarely clogs. The hole that supplies exhaust is the one with the pipe attached. The other goes into the intake.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 08-03-2010, 07:21 AM
Thanks for responding - so you are saying that I've already done what I can do, yes?
Even after spraying a can down the intake it still seems to want to sputter at idle. I have 138,000 so I can't complain too much.
Old 08-03-2010, 10:08 PM
amigo-2k amigo-2k is offline
Isuzu Guy
You may want to clean your butterfly in the throttlebody to help the stuttering
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 08-04-2010, 10:13 AM
And how do you do that again?
Old 08-04-2010, 10:49 AM
su_jumptd su_jumptd is offline
This might help concerning the ERG Valve issue.
http://www.automotiveforums.com/vbul....php?t=1010985
Old 11-04-2010, 09:17 PM
chevyrulez1 chevyrulez1 is offline
Read this
http://www.automotiveforums.com/vbul....php?t=1053354
Old 12-06-2010, 04:19 AM
That cured the sputtering.
