Go Back   Automotive Forums Car Chat > Mercury > Monterey
Old 07-31-2010, 09:47 AM
thetandycollector thetandycollector is offline
Send a message via MSN to thetandycollector
2004 Monterey - Misfire
I have a Mercury Monterey in the shop that has a random misfire. Tried cleaning the injectors, replacing fuel and air filters, checking fuel quality, plugs and wires (which I may add are a pain in the rear to find). Still misses, gets worse when AC Compressor kicks in, seems to run fine at Hwy speeds. No codes except random misfire. Help?
Bill - Eagle Automotive
Old 07-31-2010, 10:49 AM
TRINI55 TRINI55 is offline
Re: 2004 Monterey - Misfire
Tandy
engine misfire under load, re-check wires and may need to replace plugs also
hami
Old 09-04-2010, 04:26 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
has this had a new cam sensor put in it recently? I have seen a lot of them put in wrong and cause random miss issues. also had a few under tsb with egr sticking open. also check imrc runner control for binding and miss at low rpm.
-=-=-DANE-=-=-
Old 12-02-2010, 08:58 PM
Problem solved guys, do appreciate the input. Coil pack was actually hairlined down one side and was not applying enough current intermittently to two cylinders. Thanks!
