| General Tools Discussions about tools - there are thousands of various tools you can use to work on your car. Do you have the right one for the job? |
Eight Points for Attention when using the spray gun
First, we must use personal protection
When using the spray gun, a large majority of the volatile organic gases and organic gases which are harmful to human body. Most of the operators will not be bothered too much attention to their protection. However, to health, or have to carry to protect themselves, should be in operation when the gun must wear good protective equipment, such as, painting protective clothing, safety glasses, activated carbon masks, anti-thinner gloves. Second, to timely adjust air pressure Junction with the compressed air pipe and the diameter and length increase, the pressure will drop. Low pressure spray gun paint orange peel pattern will lead to serious adverse atomization. Therefore, at the entrance to the air gun pressure measurement is very important. Third, the use of low purity of compressed air Compressed air impurities, such as: particles, water, oil, spray effects will not achieve optimal results. Spray to achieve the best results, the best air purification is an absolute requirement. Fourth, using the wrong cleaning tool When the Spray gun cleaning, use the wrong type of cleaning tool will lead to spray and spray effect damage, so you should use a professional spray gun cleaning tool.Writer recommended to go Xinwei Machinery (www.zgxinwei.com) see next. Fifth, spray gun cleaning, the application of special oil spray lubrication friction of all removable parts, be careful not to spread on the front needle gun. Sixth, using the matching accessories When the gun air filter tipped tail compressed air leak occurs, immediately replace the same specifications and tipped the air connector, can not paper tape, or other similar objects instead of seals to avoid debris from entering the tape gun in the air duct, channel blockage caused by the air gun. Seventh, spraying and gun cleaning solvents used in non-acidic or alkaline to use liquid (such as recycling solvent), or likely to cause corrosion damage to gun parts. Eighth, Digital spray gun, unless replacement battery, you may not open the battery box! Each time you open the battery box, must replace the entire battery set. If you have used the battery box lids, will cause the battery Mifengbuyan, while products are not entitled to warranty. |
