Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 05-14-2003, 04:58 PM
Nissan-dj Nissan-dj is offline
Exclamation turbocharging
Ok I am looking to turbocharge a 1986 CA20(E) non-turbo engine. I have a pretty good understanding of the whole process of turbocharging.
Now my problem is I have heard that this particular engine is not designed for boost. So that leaves me with two questions
1.What is needed to make this engine an engine that can accept spme boost.
2.If there is nothign you can do how much boost psi do you think it can handle, without damageing the engine.
I would prefer to go with option number one, because I am about to open the engine up and rebuild it, so while I'm here I might as well make it an engine that can accept some boost
Old 05-14-2003, 05:24 PM
kaoru-tochiro's Avatar
kaoru-tochiro kaoru-tochiro is offline
Banned
reduce compression ratio.
I'm not sure wether you can get a thicker head gasket or get a stroker crank....or difrent pistones...
Old 05-14-2003, 05:29 PM
Ok how much should it be reduced by....I am assuming it currently has a compression ratio of 8.5:1
Old 08-14-2003, 07:39 AM
salonen salonen is offline
then it's ok (the compression ratio)... SR20DET has the same ratio (original 200sx turbo engine).
turbocharger or supercharger J_U_ice Forced Induction 3 05-18-2009 09:07 PM
Twin turbocharging Vs. single turbocharging. Hypsi87 Non Specific 31 04-23-2005 08:26 PM
Overview: supercharger vs. turbocharger texan by texan (Brian) 28 11-23-2003 01:15 PM
Turbocharger v Supercharger Mr Roboto Engineering/ Technical 3 04-21-2003 02:36 PM
Anyone want to turbocharge their max? Why supercharge when you can turbocharge? 2k2max6sp Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 05-12-2002 11:15 PM
