Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 07-29-2010, 11:15 PM
dody dody is offline
Cooling fan out of balance
2003 2.0l 5spd Fan motor connector came loose and hit plastic
cooling fan and broke a 4" piece out between two blades. Repaired
with some fine wire and epoxy but added enough weight I'm guessing
to distort balance of blade when running, causes some vibration.
Any suggestions how I can balance fan appreciated. Hate to spend
the bucks to replace motor and blade when runs great. Only 50K on
car. THANKS FOR ANY HELP!
Old 07-29-2010, 11:54 PM
Franco2112 Franco2112 is offline
Re: Cooling fan out of balance
Better served to just replace the fan. You don't want to overheat your engine with a fan malfunction. $200 turns into $4000 with a new engine. It's easy to remove and disconnect. Shop around for the best price. I use germanautoparts.com, ecstuning.com, rockauto.com and vwpartsdepartment.com. Hope this helps!
Franco
