Old 07-29-2010, 01:43 PM
Miniman44 Miniman44 is offline
1996 Taurus Electrical problem
Hi All
I have a 1996 Taurus GL 4 door sedan
the High beam indicator on the dash does not come on when high beams are on
Under dash lights and luggage compartment lights don't work either
I don't know if these are related but think they must be
Everything else on the car works
Checked all fuses. Visually look good
What else to check?
Any advise would be great
Old 07-31-2010, 01:00 PM
sjf7351 sjf7351 is offline
Re: 1996 Taurus Electrical problem
If your high beams work then most likely the high beam bulb in the cluster is burned out. Same thing with the lights under the dash if the interior light works check the bulbs. Might just want to replace them they are not the expensive.
2006 Black Grand Prix GXP
Old 07-31-2010, 01:36 PM
Hi. thanks for replying.
I have changed the cluster bulb and some of the interior bulbs.
Still, no high beam indicator and some of the interior lights
Also noticed that the parking brake indicator light is not working.
Old 07-31-2010, 08:58 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
There is an interior lamp relay that controls power to the interior lights. It receives power from 10-amp fuse #27 in the instrument panel fuse panel. The interior lamp relay is in this fuse panel as well. I'd suggest you start by checking for power to the relay. Do you have a wiring diagram for your car? Are you comfortable with a multimeter or test light and checking automotive wiring?
The high beam indicator is powered directly from the same circuit as the high beam headlights, unless your car has Daytime Running Lamps (DRLs).
-Rod
