Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 07-28-2010, 06:24 PM
FL 3.2L FL 3.2L is offline
Electrical issue when hot - no power/start
Hi!
I have a friend in CT where it's been hot. When she first drives the Burb in the am, it starts and runs without issue. But if she shuts it off at her destination, then tries to restart, she has no power and the engine won't crank. Nothing. After it cools off a bit, she can restart it as if nothing happened. Factory alarm issue that I've read about online? Any other ideas?
Thanks!
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 07-28-2010, 06:48 PM
maxwedge maxwedge is offline
A990 racer
Re: Electrical issue when hot - no power/start
Start with bad battery connections.
Old 07-28-2010, 07:13 PM
Thanks for replying. I have mentioned grounds and battery and starter connections to her. Trying to figure out what could cut power to the entire vehicle and a bad battery connection would do it...
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 07-28-2010, 07:55 PM
j cAT j cAT is offline
this time of year many a battery dies a sudden death...the heat stresses out the internal plates of the battery..have her bring to a battery retailer that can load test the battery ...this will reveal whats up..
battery 5-7yrs old 80% chance bad battery cell..just did one last week ..
as mentioned a bad connection will cause poor charging as well as slow intermittent cranking power...
Old 07-30-2010, 12:27 AM
grumpy5 grumpy5 is offline
I would look at the ignition module. If the battery connection was loose the problem would be more consistant
Old 07-30-2010, 12:54 AM
Happy Meal's Avatar
Happy Meal Happy Meal is offline
Another vote for battery. I've also seen failing starters do that.
Old 08-01-2010, 09:48 AM
Thanks for all the ideas. I'll post when I hear the solution....
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 08-26-2010, 11:31 AM
Sorry for the late post. It was a simple fix - a loose battery cable! Thanks for your help!
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
