Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-28-2010, 04:40 PM
SourD4Me SourD4Me is offline
Engine knock
Hi guys im new to the forum, my names jimmy. Anyway i was getting off the highway and it felt as if my engine was going to seize up and then it went back to normal but after that i had a bad knocking noise so i pulled over and got towed home. I then checked timing and it is good. So i drained my oil and i didn't find any metal at all so then i took my oil pan off. I am trying to get the rod caps off to take a look at the bearings to see how they are. I then noticed 1 out of the for rods wiggle a tiny bit could this be the knocking?
I also still cannot get the rod caps off i have removed the 2 bolts is there anything else i am missing? thanks!
Old 07-31-2010, 04:50 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Engine knock
If that rod cap moves then its a spun bearings. You may have to tap the caps off sometimes they are suctioned down by the oil. Time for a rebuild
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
