Go Back   Automotive Forums Car Chat > Isuzu > Amigo
Old 07-28-2010, 12:12 AM
medic733 medic733 is offline
How to remove 2000 Amigo hard top?
I'm trying to figure out if it's possible/easy to remove the hard top from a friend's 2000 Amigo. I found the bolts that obviously need to be removed from the interior side of the top, but am wondering what else is connected. Any advice and instruction would be appreciated!
Old 01-25-2011, 05:45 PM
Volume311 Volume311 is offline
Re: How to remove 2000 Amigo hard top?
You probably figured this out already but here it is.
There's a total of 10 bolts holding it down. Pull all the cladding off on the inside back half to make life easier. On each side - 2 up front on the metal flat bars to the roof, 1 midway of the window next to the roll bar, and 2 on the corners on the outside behind the removable corner piece.
On the left side, inside behind the panel should be a 4 wire connector for the brake light, on the right side is a small hose hook up for the washer.
