Old 07-27-2010, 02:12 PM
km2002 km2002 is offline
Oil light at idle
Need some educated guesses (which means, no, I have no idea what to test, so suggestions regarding proper testing are way premature at this juncture; thank you very much). My wife's 93 Taurus wagon displays a flickering oil pressure light at idle. I've checked the oil level; it's good. And the engine isn't running rough at idle, either. What are the other most likely reasons this light would flicker at idle? Thanks.
Old 07-27-2010, 08:08 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Oil light at idle
Bad oil pressure switch. Is it also leaking oil?
-Rod
Old 07-28-2010, 09:58 AM
65comet's Avatar
65comet 65comet is offline
Oil pump worn out. Oil pickup tube gunked up. Oil filter gunked up. Putting in a super light weight oil instead of the recommended or higher weight. Those are a few more.
Old 07-28-2010, 09:02 PM
Thank you both. For the record: using the specified oil; no noticeable oil leak. We do need to change the oil. That has to wait until we get back from a weekend out of town.
