Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 07-27-2010, 10:52 AM
huskym1025 huskym1025 is offline
Help!!
I have a 99 Chevy Tahoe 4wd, 5.7 engine. I just noticed when using my a/c or heat, the air comes out the defrost vents no matter where I turn the vent selector knob to. Is the control knob bad or do I have a hose disconnected somewhere? Thanks!
Old 07-27-2010, 11:34 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Help!!
I think that one still uses vacuum to control the mode doors. Check for a vacuum leaks under the hood.
Old 08-03-2010, 12:04 PM
chris peter chris peter is offline
Re: Help!!
It is the motor that controls the air direction located at the bottom of the floor vent on the gas pedal side 3 screws hold it on I think, then unplug wiring harness quick disconnect and replace the part DORMAN Part # 604107 {#89018395, 89018681}
Controls A/C Blend Door; Temperature & Mode Door; Main Unit; w/AC
You can get it at most auto parts stores for under $50
Old 08-03-2010, 12:53 PM
Airjer_'s Avatar
Re: Help!!
The blend door and mode door are two different things.
Old 08-03-2010, 02:12 PM
Re: Help!!
They are two different things. This system has 3 doors they all use the same motor part number. At least on my 99 Tahoe.
