Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-25-2010, 09:05 PM
qwertydog qwertydog is offline
5.2ltr fuel consumption
Hi, I am going to look at a '97 Grand Cherokee with the 318 motor and automatic trans. Any idea what mpg I should get with this ? I have been looking for one with the 4.0 straight six, but they are very rare around here. I know the 318 are very reliable so if the mpg is not too bad that might be a good second choice. Thanks for any advice you can give me.
Old 07-26-2010, 06:22 AM
jeeppyfan's Avatar
jeeppyfan jeeppyfan is offline
Re: 5.2ltr fuel consumption
Personally I recommend the V8. My son had the I6 and gas millage is about the same as my V8. You will get more power and fun with the V8, I have two and I don't regret it. I can do 20 liters/100km in town and 16 liters/100km on highway.
Old 07-28-2010, 11:12 AM
Musky on the Fly Musky on the Fly is offline
I am looking at a 96 jgcl, 5.2l v8, is there anything I should be wary of or look at before I buy.
Old 07-28-2010, 11:49 AM
jeeppyfan's Avatar
Here's what you should look: Body and under frame rust, transfer case operation (low and high gear), oil pan leaks, lower arms bushings (they are probably worn t out), sway bar links, drives shaft seals, any other leaks by looking underneath. Don't be scared of drive test it before you buy. Make sure transmission shifts all gears smoothly and in good relation with motor RPM. Turn off radio to ear any suspect noises. Don't get me wrong, these are reliable trucks if it has been pampered. You can make more than 300,000km with it. I have two (me and my wife) and glad to have them.
Old 08-01-2010, 10:39 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
If you have the full time 4wd system, test the viscous coupler in the transfer case by going in a tight circle, or figure 8. If the vehicle lurches then you need a new viscous coupler.
+1 on the mpg being same as the 6 cylinder. If you keep your foot out of it.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
