Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-25-2010, 08:13 PM
killermrob83 killermrob83 is offline
transmission removal
While under my dad's '99 CV for other repairs, I noticed that the rear main seal is leaking. There is also some indication that the rear seal on the transmission tail piece is leaking. How difficult would it be to remove/reinstall the transmission with the vehicle up on jack stands in the driveway? Approximately how much does the transmission weigh? Is there some kind of a transmission lift that is small enough to fit under a vehicle on jack stands? I won't have a problem replacing the rear main seal once the transmission is removed, but what does it take to replace the rear seal on the transmission?
Old 07-26-2010, 12:49 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: transmission removal
I never removed mine yet. I just asked the same question because I wanted to change the torque converter but most say it's a PITA.
If the leak isn't that bad, you could probably get away with leaving it be.
The tailshaft housing seal should be straight forward by removing the drive shaft. While the driveshaft is off, it's a great time to replace the U-joints.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 07-28-2010, 06:42 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
They make a low profile transmission jack that only raises a little over 24 inches. See if a local parts house has a loaner or one you can rent. If you get the jack, it is not that hard. You need to either twist, turn and manuever the transmission to get it to clear the converter. Or remove the converter. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-29-2010, 07:06 PM
rhandwor rhandwor is offline
Doing one with a floor jack you will need someone to raise and lower the jack and help hold the transmission.
Old 07-30-2010, 09:39 AM
I will definitely look into the transmission floor jack loan out/rental situation. Does the exhaust system or any part thereof need to be removed to pull the transmission? It didn't appear to me to be in the way, unless blocking access to some of the bolts that need to be removed, although I only looked it over briefly.
Old 07-30-2010, 12:26 PM
way2old's Avatar
TOKEN HILLBILLY
There is room to remove it without removal of the exhaust. That is where the twisting and turning of the transmission comes in. I think the right side is close due to the starter mounting.
