Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 07-24-2010, 10:34 PM
Paul94Z28 Paul94Z28 is offline
84 Sunbird Leak when hot
Hi-
My 84 1.8 turbo leaks profusely from the oil pan/block/pump joint when it gets to 180. It does not leak if the temp is below that. I run 20w50 oil.
I have done the pan gasket 4 times and that does not appear to be it. I recently replaced the oil pressure sending unit and the pressure is normal. Sending unit is dry.
Any thoughts would be appreciated.
Thanks,
Paul
Old 06-13-2012, 01:08 PM
Re: 84 Sunbird Leak when hot
It was the Oil Pump. Once it heated up, the seals let go.
