Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 07-24-2010, 04:11 PM
ml_jones2010 ml_jones2010 is offline
1997 Grand Marquis flashing lights problem HELP ME PLEASE!
I was on the highway last night and turned on my hazard lights. They were working at first then i noticed they stopped flashing. I turned the hazards off but then I noticed my turn signals were not working while I was switching lanes. Once I was stopped I looked at all the lights and found that all the parking lights were working but all lights that flash including the brake lights did not work. Today I checked ALL of the fuses in the fusebox under the dash with my electronic meter and found ALL of are showing continuity. Is there anybody here that has had this problem? If so please tell me parts I should check next
Old 07-25-2010, 05:23 PM
Johnobub Johnobub is offline
Re: 1997 Grand Marquis flashing lights problem HELP ME PLEASE!
Try replacing the flashers. there are two flashers located under the dash. that should fix the problem.
Old 09-04-2010, 04:23 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
the multi-function switch is bad. I replaced about 10 a month for this. you don't use hazzards and the switch corrodes. then when you do use it it crusts the rest of the contacts. or turn on the hazzards and shake the crap out of the hazzard switch, smack it on and off a few times and see if they all come back to life.
-=-=-DANE-=-=-
