Old 05-14-2003, 12:27 PM
chopstick1981 chopstick1981 is offline
stupid axle nut!
is the driver's side axle nut one of those that twist opposite of normal? only reason i ask is cuz i have a three foot breaker bar on it and the damn thing won't budge.
Old 05-14-2003, 12:34 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Take my word for it, it is conventional:
"Rightsey tightsey, leftsey loosey.."
Get your big-assed cheater pipe, a good socket, and a couple of friends.
Make sure your car is on the ground when you do this, no jack, jackstands, or otherwise. Chock the tires.
Or just go to a shop and have someone hit it with the air impact like I did!
Flunky
PS-You have used a screwdriver to pry that little tab up, right?
Old 05-14-2003, 12:52 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
they hammer part of the nut into a notch usually so it doesn't slip, so check that first, then throw on some steelies and put it back on the ground and go at it with a wrench or impact gun.
Empty Pockets Racing Member #1
Old 05-14-2003, 04:15 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah when i was doing my swap i forget to take out the bend on one of the nuts. it was funny because i just did it tot he drivers side, then i go to the passenger side and i put my socket on and i try to take it off, and my dad comes out and goes did u take out the bend in the nut, i hope u did because u just did it tot he drivers side, i felt pretty stupid. but on another note, i did break 2 screwdrivers trying to get the bend out and straight
Team Lonely Drivers
Old 05-14-2003, 04:46 PM
markzippy markzippy is offline
How was the nut put on originally? I was stupid and had it put on with an impact whrench and the only way I could get it off was have my mechanic cut it off with a torch. I snapped a brand new 1/2" breaker bar with a six foot extension pipe. Impacts do not work for this situation.
Old 05-14-2003, 05:33 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
impact gun.....only way i got mine off, bent a 1/2 steel screwdriver in half, bent 3/4 inch crow bar in half.....go impact
you must have a cheap one or something was wrong with it
2002 Acura TL Type S
1991 Honda Crx Si
Old 05-14-2003, 06:36 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Originally posted by civicHBsi91
you must have a cheap one or something was wrong with it [/b]
I agree. It would take a nice impact gun to take that off. To tell you the truth sometimes it doesn't always work but its worth a try. This is what i did. I took the chizel and a hammer and i loosen it up that way. IT really works
Old 05-14-2003, 08:53 PM
damn nut! I wrestled around with it for another couple hours, no luck. The only reason i needed it off was to take out the drive axle and remove a bad alternator, instead i just removed the rear motor mount and the alternator slipped right outta there, only had to undo 4 bolts.
Old 05-15-2003, 02:15 AM
TrailerParkJake TrailerParkJake is offline
Send a message via Yahoo to TrailerParkJake
i used a 7 foot pipe on the end of my ratchet, and had to jump on it about five times to break mine free...but not before breaking another ratchet :o
When I started reading about the evils of alcohol, I quit reading .
Old 05-15-2003, 09:59 AM
AF Premium User
Hey, Trailerpark Jake!
I hope it was a craftsman ratchet. At least they'll replace it for free. Even if they have free replacement, that still won't get the nut off. That's when it's time....for SNAP-ON!
Flunky
PS-I'm still sad I had to sell 99% of my Snap-On tools.
Old 05-15-2003, 11:35 AM
Flunky
of course it was craftsman, how do you think i got another one the same day:smoka: I love misusing their tools
