Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 07-24-2010, 02:39 PM
TERRBALL TERRBALL is offline
03 tacoma window issues
My 03 taco has a problem with the driver side window not going up sometimes, or a little bit at a time. It's automatic. Is it a switch issue? The motor? Any help/advice would be appreciated! Thanks ahead of time!
Old 09-27-2010, 09:06 AM
J.C. Robbins J.C. Robbins is offline
Re: 03 tacoma window issues
I have an 03 taco and I have had the same problem a couple of times. Mine acted up after raising the window up and down several times. I eventually got it to go up after waiting a minute. I am not sure what the cause was. It works perfectly most of the time so I am going to wait to fix it. I know this doesn't help you with your problem but I just wanted you to know that you were not alone.
Old 02-01-2011, 10:08 PM
wulam wulam is offline
I have had the same problem, its the window motor going out. After replacing it window work fine
Old 07-23-2011, 09:31 AM
TacomaMan.'s Avatar
TacomaMan. TacomaMan. is offline
My 03 driver door window does it too. and I had to hold my button while i opened and slamed the door and it rolled up.
Old 08-06-2011, 08:31 AM
HAHHAAH!!!! slamming the door is awesome! I've recently had the actuator replaced and it works good as new!
Tags
motor , switch , window
