Old 07-22-2010, 07:36 PM
ame92 ame92 is offline
Exclamation ABS/Trac Off light
I have The ABS and Trac control light on.
brought my car to the shop to see if they could figure out what was wrong and they gave me the codes:
C1226 Right Front Excessive Wheel Speed Variation
C1225 Left Front Excessive Wheel Speed Variation
C1222 Right Front Wheel Speed Sensor Input Signal is 0
C1233 Right Front Wheel Speed Circuit Open or Shorted
C1293 Code C1291 Set in Previous Ignition Cycle
C1291 Open Brake Lamp Switch Contacts During Deceleration
Just wondering what i could do to fix these codes.
thank you
Old 07-22-2010, 11:15 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: ABS/Trac Off light
Check the wiring for the right front wheel speed sensor to start. If it looks O.K. you can check the output of the speed sensor with a volt meter set to a/c voltage. Compare to the other side to see if the readings are the same if not replace the hub/bearing assembly.
Old 10-18-2010, 08:50 AM
MallocArray MallocArray is offline
To confirm what AirJer said, check the wiring for the wheel speed sensor. Mine was wrapped and I had to cut the sheath off to view the actual wires. In my case the wires were good, so I ended up replacing the wheel hub bearings on the front and the errors went away.
Old 10-30-2010, 12:56 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF ame92 !
Sounds like you have a bad wheel speed sensor or as stated above possibly a short in the wiring. They should ohm out around 2000 ohms i think.
Also If you have it on jack stands and you rotate the wheel(in nuetral) while checking the ohms reading, it should fluctuate smoothly as the speed increases/decreases, not erraticlly jumping around. If it's jumping around the HUB sensor is bad.
And i would NOT remove that wire protector completely or you could have other issues down the road.
1999 Grand Am SS 3.4 OHV
