Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 07-22-2010, 04:15 PM
chrisinsurance chrisinsurance is offline
Trying to get the 95 back on the road
I have a 95 that has been out for about a yr. Having to replace the dual pulley for the water pump. Changing the plugs and also having someone to rework the cluster that is bad. I also have service engine light, blower motor for AC not working. The trans axle light and ABS light also come on.
I also either need a fuel filter and maybe even a pump. Where is the fuel filter located? Under the hood or is this one in the pump? I really need to get this car running again.
Old 07-23-2010, 12:09 PM
peeweewasblue peeweewasblue is offline
Re: Trying to get the 95 back on the road
Under the body, forward of the left rear tire. Be sure to relieve the pressure before changing it.
Old 12-28-2010, 01:10 AM
papasmithnc papasmithnc is offline
Banned
From the sounds of it, the only way you're going to get that vehicle on the road is behind a tow truck. Seriously, please look at the threads on this car especially the early years. These cars are one of the most unreliable cars on the road. Well, maybe not on the road. Maybe on the side of the road, in the yard with the transmission pulled out, under a tree, in the junk yard, at the shop, on fire, etc. Anyway, you get the picture.
Really, you will be throwing good money after bad if you have that many problems. And, after you fix them, another problem will soon crop up. Such is the nightmare that is the Aurora.
