Old 07-22-2010, 12:37 PM
blk95lumina blk95lumina is offline
Touchy Brakes at Startup
Hello.
I have a 95 Lumina 3.1L w/ ~155K mi.
Whenever I first startup my car in the morning, the brakes are very touchy and seem to be unbalanced.
For the first few uses of the day, the rear brakes seem to make contact before the fronts, bad enough to where once I had to brake hard and the rears immediately locked up and it felt like the fronts had not made much contact at all.
All brake pads were changed at the same time some years ago and all have ~50% life remaining.
This only occurs when I first use the car for the day and only for the first few times the brakes are used. After that they seem to adjust.
Do my brakes need to be adjusted?..maybe just lubed?
Thanks.
1995 Lumina LS Sedan 3.1L - 215K mi - Daily Driver
2002 Accord EX Sedan V-6 - 209K mi - Wife's Daily Driver
2000 Silverado LS RCSB 5.3L - 168K mi
Old 07-22-2010, 06:37 PM
maxwedge maxwedge is offline
A990 racer
Re: Touchy Brakes at Startup
Pull the rear drums, there may be a lot of brake dust and when damp this can cause the brakes to grab. Rear drums I assume?
Old 07-22-2010, 08:20 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
In that scenario, assuming drum brakes, most times you're gonna find a rear wheel cylinder that is leaking slightly.
Look at the backside of the backing plates, see if one has a dark stain on the upper part where the brake line enters...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 07-22-2010, 08:39 PM
Thanks for the advice.
Yes, these are rear drums.
I'll pull the drums, inspect the cylinders, and clean everything off.
Should I avoid spraying the pads directly with brake cleaner?
Thanks.
Old 07-23-2010, 07:59 AM
A990 racer
No, you can clean up everything with brake clean.
