Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 07-22-2010, 12:42 PM
eric1h eric1h is offline
rear wheel wont sit flush...
i have one side of my rear that the wheel wont sit flush, there is a little lip on the rear hub that prevents it from sitting flush, anyone else have this? solution?
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 07-22-2010, 02:05 PM
boothkc boothkc is offline
Re: rear wheel wont sit flush...
Are you using the 17" BBS wheels? I have 24 of these and some of them didn't have the centers machined out to allow clearance for the rear axels. We just use these on the front and they work fine. PIA if you are using 2 tire sizes. You can have the holes machined out to make them all the same.
Kevin
GTS & GTRA
Old 07-22-2010, 03:05 PM
hmm, yeah that sucks! I will probably just make a couple 1/8" spacers and use them on the rear, easier than machining the wheel!
thx
Old 07-22-2010, 05:14 PM
Squerly's Avatar
Squerly Squerly is offline
Hi Eric. Did you recently change the hubs on the rear?
Squerly
Old 07-23-2010, 10:00 AM
no, its always sort of been that way, even with the wheels from panoz... I just tried to center the wheel as best i could, but it needs to be addressed, anyone have a set of 5mm spacers they want to sell? :-D
Old 07-23-2010, 10:51 AM
wirewheel99 wirewheel99 is offline
Red face Re: rear wheel wont sit flush...
Hi Eric, we have lots of spacers...just need to check on the sizes..
$15 a pair.
Have a great weekend.
James
www.wirewheel.com
Old 07-23-2010, 10:56 AM
Squerly's Avatar
Originally Posted by eric1h View Post
no, its always sort of been that way, even with the wheels from panoz... I just tried to center the wheel as best i could...
You're a scary man Eric...
Squerly
Old 07-23-2010, 02:44 PM
yeah, and? :-D I've been called a lot of things, cautious has never been one of them! :-D
I never really realized what was wrong, i just knew the wheel had a hard time sitting flush but seemed to sort itself out once i torqued everything down, but at the last event i realized what was wrong!
In my defense, I've only swapped tires on my car TWICE in 2 years, so its easy to forget these things
Old 07-23-2010, 02:52 PM
wirewheel to the rescue again! Money sent, thanks James/Hayes!
